2003 caravan 3.3L won't start
Old May 9, 2010 | 06:28 PM
imfranco67's Avatar
imfranco67
Default 2003 caravan 3.3L won't start
I have a 2003 caravan sports, It just won't start, cracking, no everything but the battery is ok. the panel shows abs and vehiccle theft alarm light. brought it to a mechanic but he said the PCM is not communicating to the computer he attach.
pls. help
Old May 9, 2010 | 09:58 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
When did this problem start? Did you start the van with a non program key?
Old May 10, 2010 | 09:13 PM
imfranco67's Avatar
imfranco67
Default key's
I used the original key to start the van, It just rain the whole night and the next morning it won't start.
Old May 10, 2010 | 10:17 PM
master tech
Did you ck all the connectors to the pcm? You may have gotten water into a connector thats causing your no start problem.
Old May 11, 2010 | 06:24 PM
imfranco67's Avatar
imfranco67
Default dodge 2003
I ck the wiring and terminals all ok. do you think it's the PCM itself has a problem?
Old May 11, 2010 | 10:10 PM
master tech
Without seeing the van, I'm only guessing.Your best bet is get the van into the shop and have the pro's work on it. They would have all the testers and tools to find the problem. And give them as much information when the problem started.
