A/C problem - no rad fan
Old May 9, 2010 | 09:32 PM
tscaravan's Avatar
tscaravan
Default A/C problem - no rad fan
2004 T&C, 3.3L, A/C is manual 3-zone
When the A/C is on, the radiator fans don't come on. Like, not at all ever. The pressures and liquid line temp get fairly high and keep creeping up. Like 50/250 psi at 50F ambient after 3-4 minutes.
There are no leaks in the system and the pressure transducer works fine. Any idea as to why the PCM doesn't turn the fans on? The fans do kick on when water temp gets high enough.
Any ideas appreciated.
Old May 9, 2010 | 10:03 PM
master tech's Avatar
master tech
Site Moderator & Tech
Does the A/C compressor come on with A/C turn on? You could have a bad fan relay. Thats mount on the front bumper on the passenger side. If you have access to a DRB3 scanner, actuate the fan and see if it comes on. If it don't the relay is most likey your cause.
Old May 9, 2010 | 10:42 PM
tscaravan's Avatar
tscaravan
Yes the compressor comes on.
The fan relay is fine, it turns on the fan when the engine water comes up to temperature.
Old May 11, 2010 | 09:17 AM
tscaravan's Avatar
tscaravan
Ideas, anyone?
Old May 11, 2010 | 12:06 PM
Tizzy1's Avatar
Tizzy1
The condenser fan does not turn on until system high side pressure reaches 250psi. Try it when it gets warmer outside and the pressures get higher. With cooler outside temps, it is not uncommon for the fan not to run.
Old May 12, 2010 | 01:01 AM
tscaravan's Avatar
tscaravan
It did reach over 250 psi after a few minutes running, when I had a manifold set connected. The pressure transducer put out about 2 volts at that point. Fans didn't come on.
Old May 12, 2010 | 08:23 AM
vabear's Avatar
vabear
Default No Fans with AC
Couple of thoughts. First the AC fan relay in the fuse box under the hood, check it out. If the temp sensor was bad you would not have fans at high temp so that is good, and obviously the fan motors are good.
Old May 12, 2010 | 11:07 AM
Tizzy1's Avatar
Tizzy1
I would need an actual temp reading from a scan tool to tell for sure.
Old May 13, 2010 | 09:04 AM
tscaravan's Avatar
tscaravan
Which temp? IAT? There is no refrigerant temp sensor.
Old May 13, 2010 | 09:10 AM
Tizzy1's Avatar
Tizzy1
Sorry, high side pressure reading from the transducer.
