How do I remove passenger power window mount?
Old May 14, 2010 | 10:19 PM
dakiddy's Avatar
dakiddy
Default How do I remove passenger power window mount?
Hi, I recently got a 97 Caravan Sport, so today I was about to leave and its hot weather so I put the windows down as usual, but like the passenger window went down.
Then I saw like the cable like come out top from underneath so I tried to make the window go up, and it does not go up anymore it only goes down, so I took the whole thing apart and I want to replace the whole system because I have a spare door but I am stuck because I cannot take the screws out from the mount thing cause there is this rubber thing and when I turn the screw the whole screw turns... to make it easier to understand I took pics:
so my question is, how do I take the screws out? and or any solutions on how to transfer the stuff from the working door to my current one?
Old May 14, 2010 | 11:52 PM
master tech's Avatar
master tech
Site Moderator & Tech
You need to put a visegrip on the nut side and hold. Then remove the srcews. You will need to replace the screws, part number is 4796315ab and nuts 4796314, You'll need 3 of each.
Old May 15, 2010 | 09:09 AM
dakiddy's Avatar
dakiddy
thanks, I was thinking the same thing, but mines are rusted! Thanks for the part numbers!
