'97 grand carvan rotor/brake question
Old May 21, 2010 | 11:43 PM
dmoss74's Avatar
dmoss74
Default '97 grand carvan rotor/brake question
hi,
i just changed the front brake pads on a '97 GC, but when doing it, the rotors would just move around loosely. is that normal? does the rotor tighten down when the brake assembly is put together? her car was making a noise afterthe brakes went in, like the wheel bearing would be bad.
any help would be great.
Old May 22, 2010 | 12:03 AM
master tech's Avatar
master tech
Site Moderator & Tech
The wheels are what keep the rotor's tight on the hub. Did you have the noise before the brake pads? And before i forget, Welcome to DF.
Old May 22, 2010 | 12:08 AM
dmoss74's Avatar
dmoss74
hi, thanks, and no, the noise wasn't that bad. it sounds (it's not my car) like wheel bearings, or a bad spindle. could it just be the new pads wearing in a little?
Old May 22, 2010 | 12:18 AM
master tech
It maybe the axle/hub bearing. Not the brake pads.
Old May 22, 2010 | 12:37 AM
dmoss74's Avatar
dmoss74
thanks, i'll have her check that.
