Runaway Idle After intake removal
Old May 22, 2010 | 09:52 PM
m4d4n's Avatar
m4d4n
Default Runaway Idle After intake removal
Ok I did a search and don't see this one so I have a 3.3 rough idle pull the intake check the injectors all 12ohm alright put everything back together engine red lines on start,
Pull the throtle body check resistance on TPS, good. I have no idea how to check the idle air motor and don't think it can red line the engine any way. pulled the map sensor, replaced it same thing, leave it outside the intake hits 3k and stalls. What else is there to check all vac hoses are connected.
I need help. please
Old May 23, 2010 | 02:51 PM
m4d4n's Avatar
m4d4n
Just an update no codes either.
Old May 23, 2010 | 06:38 PM
master tech's Avatar
master tech
Site Moderator & Tech
You may have a vacuum leak, from the egr tube. Or missing gasket.
Old May 24, 2010 | 07:50 AM
m4d4n's Avatar
m4d4n
which gasket ?
egr hoses are pretty tight.
Old May 24, 2010 | 09:14 PM
m4d4n's Avatar
m4d4n
master tech your the man. Plenum gasket was destroyed replaced it runs like a clock thanks.
