05 Grand Caravan Front AC quit working
Old May 31, 2010 | 02:11 PM
LVCaravan's Avatar
LVCaravan
Default 05 Grand Caravan Front AC quit working
Last night AC worked fine on the way to my destination but when I came out the front would not work. The rear AC still blows cold as ever. I can feel a very small amount of cold air coming through the front vents but way less than even when on low. Check fuses and relays under hood and all are fine. Any advice?
Old Jun 1, 2010 | 11:09 AM
Tizzy1's Avatar
Tizzy1
H-valve sticking or a leak and the system is low.
Old Jun 1, 2010 | 08:17 PM
LVCaravan's Avatar
LVCaravan
What is the H-valve? Noticed today that cold air seems to come out a little bit when pushing the gas pedal and completely stops when idle.
Old Jun 2, 2010 | 09:14 AM
Tizzy1's Avatar
Tizzy1
The h-valve is what meters the freon into the evaperator. If you follow the a/c lines under the hood until they get to the fire wall, the h-valve is what they connect to. A large alluminum block.
Old Jun 2, 2010 | 07:51 PM
LVCaravan's Avatar
LVCaravan
Can you tell by looking at it if it is stuck? Can it be cleaned or does it need to be replaced?
Old Jun 2, 2010 | 08:45 PM
master tech's Avatar
master tech
Site Moderator & Tech
If the H-valve is stuck, then you replace it with a new one.
