2000 Dodge Caravan transmission problems
Old Jun 3, 2010 | 08:15 PM
arse87zx's Avatar
arse87zx
Default 2000 Dodge Caravan transmission problems
I need to remove the transmission to get it rebuilt. Is the engine cradle going to need to be removed to pull out the trans. or is there any special tools i will need? Any help would be greatly appreciated.
Old Jun 3, 2010 | 08:50 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
You need to support the back of the engine. Sockets you need,18mm,10mm,8mm,15mm and13mm. and 18mm box wrench to remove the torque converter bolts.No you don't drop the cradle unless you have an all wheel drive. In which case you would remove just the plate.
