97 Caravan antifreeze leaking - heater core?
Old Jun 13, 2010 | 12:39 AM
jonphilip's Avatar
jonphilip
Default 97 Caravan antifreeze leaking - heater core?
hi, I have 97 Caravan and today I noticed a big puddle of anti-freeze on the drive. After popping the hood, I noticed the anti-freeze was coming out of the drain tube that protrudes through the firewall on the left side. I've been researching this today on Google but can't find a conclusive answer as to what would cause it to leak from the drain tube. There is no anti-freeze inside the van, and I don't notice any smell of anti-freeze when running the heater. The heater doesn't work very well and hasn't for several years. It gets warm but not hot. I'm wondering if it is a bad heater core, but everything I read about heater cores failing indicate it should be leaking inside the van, which it's not. Any expert advice would be greatly appreciated! Thanks, JonPhilip
Old Jun 13, 2010 | 01:19 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Before making any repairs, do a cooling system pressure test. And then see if the coolant/water is coming out of the tube.If the heater core is the problem, the dash would need to be remove to remove the heater box assy.
Old Jun 14, 2010 | 09:26 PM
jonphilip's Avatar
jonphilip
hi, thanks for the welcome and response. I will take your advice and have a pressure test done. can you tell what's on the other end of the drain tube when it goes into the firewall? I'm curious as to the purpose of the drain? is it for the heater core or does it serve another function? thanks... jonphilip
Old Jun 14, 2010 | 09:56 PM
master tech
Its for the a/c, to let condensation drain out.
