Tools required for Rear brake job 2009 GC
Old Jun 16, 2010 | 11:59 AM
chaddupuis's Avatar
chaddupuis
Default Tools required for Rear brake job 2009 GC
Hi all, first post here.
getting ready to replace pads and rotors rear only on my 2009 Grand Caravan. Very little in the way of service manuals available to the public so i figured I would ask here. i simply need a list of all tools and sizes to complete the job. I already know I need the Piston compressor that will also screw the caliper piston in, I have this ready to go.
any help is appreciated.
Old Jun 16, 2010 | 12:57 PM
Tizzy1's Avatar
Tizzy1
18 mm for the caliper slide, pry bar.
Old Jun 16, 2010 | 12:58 PM
Tizzy1's Avatar
Tizzy1
I'm pretty sure me or MT have posted the service manual proceedure on here somewhere
Old Jun 16, 2010 | 11:43 PM
master tech's Avatar
master tech
Site Moderator & Tech
INSTALLATION
NOTE: Perform Step #1 through Step #6 on each side of vehicle to complete pad set installation, then proceed to Step #7 .
CAUTION: Anytime the brake rotor or brake pads are being replaced, the rear caliper piston must be seated (bottomed) to compensate for the new brake rotor or lining. Because the parking brake self-adjuster mechanism is attached to the piston, a special seating method is required. The only acceptable method is by rotating the piston back into the bore using Retractor, Special Tool 8807, as described below. Any other seating method will damage the self-adjuster mechanism.
1. If necessary, seat (bottom) the caliper piston in the bore as follows: a. Assemble a 3/8 in. drive ratchet handle and an extension.
b. Insert the extension through Special Tool 8807–1 .
c. Place Special Tool 8807–2 on the end of the extension.
d. Insert lugs on Special Tool 8807–2 into notches in face of caliper piston.
e. Thread the screw drive on 8807–1 down until it contacts the top of 8807–2 which is against the caliper piston. Do not over tighten the screw-drive. Damage to the piston can occur.
f. Turn 8807–2 with the ratchet, rotating the piston in a clockwise direction until fully seated (bottomed) in the bore. It may be necessary to turn 8807–1 with 8807–2 to start the process of piston retraction.
2. Make sure abutment shims are in place on both upper and lower slide abutments of caliper adapter .
NOTE: If the brake pads have a protective paper on the rear face of the brake pad plate, it must be removed before pad installation.
3. Place the brake pads in the abutment shims clipped into the disc brake caliper adapter bracket as shown.
CAUTION: Use care when installing the caliper (2) onto the adapter bracket to avoid damaging the guide pin boots.
4. Install the disc brake caliper (2) over the brake pads on the brake caliper adapter bracket.
CAUTION: When removing or installing a caliper guide pin bolt, it is necessary to hold the guide pin stationary while turning the bolt. Hold the guide pin stationary using a wrench placed upon the pin's hex-shaped head.
5. Align the caliper guide pin bolt holes with the adapter bracket. Install the upper and lower caliper guide pin bolts . Tighten the guide pin bolts to 35 N·m (26 ft. lbs.).
6. Install tire and wheel assembly (1) (Refer to 22 - Tires and Wheels - Installation) . Install and tighten wheel mounting nuts (3) to 135 N·m (100 ft. lbs.).
7. Lower vehicle.
8. Pump brake pedal several times to ensure vehicle has a firm brake pedal before moving vehicle.
9. Check and adjust brake fluid level as necessary.
10. Road test vehicle and make several stops to wear off any foreign material on brakes and to seat brake pads.
Old Jun 17, 2010 | 09:18 AM
chaddupuis's Avatar
chaddupuis
perfect, thanks
Old Oct 6, 2010 | 11:43 PM
46FD04's Avatar
46FD04
I own a 2009 Caravan, 3.3L engine, FWD.
How do the rear brake rotors come off?
I had the brake calipers & pads removed, and could not get the rotors off.
Don't they just slip over the 5 lugs like a front brake rotor?
Thank you.
Old Oct 9, 2010 | 05:07 PM
Tizzy1's Avatar
Tizzy1
yep, might need to hit them with a hammer to break them loose.
Old Oct 16, 2012 | 11:43 PM
amazingdad's Avatar
amazingdad
Default how about the tool kits you can buy??
Will the tool kits for disc brakes work with the 2009 caravan rear brakes? Whats the Diameter and pin spacing for the piston?
Amazon Amazon
Old Oct 17, 2012 | 10:57 PM
georgef's Avatar
georgef
I can't say for certain that that kit will work, but it probably will.*
I don't know the dimensions of the piston, but I do own the Miller Special Tool #8807, and here is a drawing I made of the -2 portion of the tool:
* I copied the image of the set you linked to and scaled the image based on the square hole in the plate in the lower right hand corner being 3/8". I then analyzed the adapter plates in the image, and it appears that the two plates in the middle at the far right are approximately the correct size.
George
Old Nov 8, 2012 | 11:51 PM
amazingdad's Avatar
amazingdad
I bought this kit and it did the job.
http://www.harborfreight.com/18-piec...kit-69053.html
