Camshaft sensor
Old Jun 18, 2010 | 07:00 PM
tsavay's Avatar
tsavay
Question Camshaft sensor
Would you happen to know where the camshaft sensor is located on a 2005 Dodge Grand Caravan SXT 3.8 ?
Old Jun 18, 2010 | 10:50 PM
master tech's Avatar
master tech
Site Moderator & Tech
REMOVAL - 3.3/3.8L
Disconnect the negative battery cable.
Remove the air box cover and inlet tube (AIR BOX COVER).
Disconnect camshaft position sensor electrical connector from the wiring harness connector (CAMSHAFT POSITION SENSOR).
Remove bolt holding sensor.
Rotate sensor away from block.
Pull sensor up out of the chain case cover. Do not pull on the sensor wiring. There is an O-ring on the body of the sensor. The O-ring may make removal difficult. A light tap to top of sensor prior to removal may reduce force needed for removal.
Old Jun 19, 2010 | 11:21 AM
tsavay's Avatar
tsavay
Smile
Thank you very much
