2000 Caravan PO171 Lean
Old Jun 24, 2010 | 11:32 AM
dodgeforce39's Avatar
dodgeforce39
Default 2000 Caravan PO171 Lean
Hi all,
New to this site hope for the best.
2000 Dodge Caravan 3.0 engine
Code PO171
Map 23.92 @2464
39 mph
Fuel sys1 - cl
Fuel sys2- cl-fault
Cal load 33.73%
ECT 194
STFT Bank 1% 24.22
LTFT Bank 1% 24.22
Have tried fuel filter, O2 sensor upstream, new plugs
It takes a few tries to start then will run but a little sluggish after it's
running for a while, back fire every now and then
Old Jun 25, 2010 | 05:14 PM
Tizzy1's Avatar
Tizzy1
Welcome to the forum, sorry for the delay. First, check the fuel pressure. If it is low, it will give you a lean condition. You can see both of the addaptive fuels are locked rich. If the fuel pressure is ok, check for vacumn leaks or leaks in the intake gasket where unmetered air can get into the engine. With the hard starting, I'm guessing fuel pump issue.
Old Jun 26, 2010 | 05:42 PM
dodgeforce39
Fuel pump yea!!!! I kinda had a hunch but with the cost of a pump i didn't
want to pull the trigger. But after your post it made me more confident that it might be. Thank goodness it was such a stress relief.
Thanks for the advice.
PS dont listen to autozone, fuel pump was like last on the list of things they said.
Old Jun 26, 2010 | 06:20 PM
Tizzy1's Avatar
Tizzy1
fixed another one!
