A few codes just popped up, now what?
p0123 tps tps sensor volt high
p0508 iac valve sense circuit low
p1486 evap leak pinched hose found
p1193 Manufacturer Control Fuel Air Metering
I recently took off the intake plenum to make it easier to replace valve cover gaskets. I unplugged a bunch of stuff, but plugged everything back in. Everything seems to run smoothly, despite the codes. Any help would be greatly appreciated. And for the pinched hose, where do I start?
Alot of those codes probably were set when you pulled the intake. You should clear them out and see if any of them come back.
When Monitored and Set Condition:
P1486-EVAP LEAK MONITOR PINCHED HOSE FOUND
When Monitored: Immediately after a cold start, with battery/ambient temperature
between 40 deg. F and 90 deg. F and coolant temperature within 10 deg. F of battery/
ambient.
Set Condition: LDP test must pass first. If the PCM suspects a pinched hose it will not set
a fault until it runs the evap purge flow monitor. If the purge monitor does not pass then the pinched hose fault will be set.between 40 deg. F and 90 deg. F and coolant temperature within 10 deg. F of battery/
ambient.
ambient.
ambient.
As far as the other codes, I will take the battery cable off and reset the codes that way...but then again, like I said, the 1486 code has been off and on since we've owned the van (for about two years). I could reset and then the check engine light show up again and be for the 1486 or one of those others mentioned.
It basically doesn't pass the purge monitor. So when the PCM actuates the purge system, it doesn't see any change in the O2 sensor operation. It should get richer when the purge is actuated so it thinks a hose is plugged. Anything mechanical that would keep the purge from flowing would cause the code.
