2003 Dodge Caravan Tempermental Window
Old Jul 1, 2010 | 10:43 PM
carl thomas's Avatar
carl thomas
Default 2003 Dodge Caravan Tempermental Window
The driver window on my Caravan sometimes works for months. Then all of a sudden it decides that it is tired of working and just stops. It always stops all the way up.
Sometimes, if you play with the switch enough, it will work again. But lately, not so much.
1. Could this be the switch?
2. For the life of me i cant figure out how to get the door panel off. Does the little panel the switches are in pop out? It sure does not seem to.
Thanks for the help.
Old Jul 2, 2010 | 12:44 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
You would to remove the door panel and ck power and ground at the window motor.If you have power and a good ground,then i would say the regulator is bad.
Old Jul 2, 2010 | 02:45 PM
Tizzy1's Avatar
Tizzy1
REMOVAL
  1. Remove the plug and remove screw attaching door pull cup to inner door panel.
  2. Remove switch bezel and disconnect power window/memory switch.
  3. Remove screws attaching trim panel to door from below map pocket.
  4. If equipped, remove window crank.
  5. Remove screw holding door trim to door panel from behind inside latch release handle .
  6. Disengage clips attaching door trim to door frame around perimeter of panel.
  7. Lift trim panel upward to disengage flange from inner belt molding at top of door.
  8. Tilt top of trim panel away from door to gain access to latch linkage.
  9. Disengage clip attaching linkage rod to inside latch release handle.
  10. Separate linkage rod from latch handle.
  11. Disconnect the power door switch, courtesy lamp electrical connectors.
  12. Remove front door trim panel from vehicle.
Old Jul 5, 2010 | 03:29 AM
login1's Avatar
login1
Can get the complete window regulator kits on Ebay for $29. Replaced both on my van.
