07 Grand Caravan SXT
Old Jul 5, 2010 | 10:12 AM
2fnloud's Avatar
2fnloud
Default 07 Grand Caravan SXT
Recently the passenger slider door lock quit working. Obviously this means that either my harness is bad or the actuator is bad.
Can anyone here give me the pin read out for that wire harness so I can test the harness with my multimeter?
Thank you for your help.
Old Jul 6, 2010 | 12:06 AM
master tech's Avatar
master tech
Site Moderator & Tech
REMOVAL
Hope this is what you were looking for.
NOTE: For power sliding door procedures refer to POWER SLIDING DOOR SYSTEM in the ELECTRICAL section.
1. Remove sliding door trim panel.
2. Remove sliding door stop bumper.
3. Peel watershield away from adhesive around perimeter of inner door panel.
4. Disengage external cable from latch/lock assembly.
5. Remove foam block.
6. Remove inside door handle assembly.
7. Disengage inside cable from latch/lock assembly.
8. Disengage link from bellcrank.
9. Disengage hold open latch cable from lower hinge.
10. Remove bolts attaching latch/lock control to sliding door .
11. If equipped, lower latch and disconnect wire connector from power door lock motor.
12. Remove latch/lock from door.
Old Jul 6, 2010 | 03:25 PM
2fnloud's Avatar
2fnloud
Master Tech not what I was looking for but info needed just the same. Can you please tell me what size torx head I need to remove the bracket that holds the striker latch and power door lock accuator to the door?
Thank you again,
Steve
Old Jul 6, 2010 | 03:37 PM
Tizzy1's Avatar
Tizzy1
It's a T15 torx and here's what your looking for
Old Jul 6, 2010 | 04:21 PM
2fnloud's Avatar
2fnloud
Thanks Tizzy1,
I have the door apart awaiting the lock motor should be in tomorrow. I just needed to know what size torx to buy.
Old Jul 6, 2010 | 05:49 PM
Tizzy1's Avatar
Tizzy1
T15 torx for the actuator and T30 torx for the latch itself to the door.
Old Jul 6, 2010 | 11:42 PM
2fnloud's Avatar
2fnloud
Got it the first time around, than you again for your help.
