enable rear spekers 2009 caravan
Old Jul 16, 2010 | 12:50 PM
mdunlop's Avatar
mdunlop
Default enable rear spekers 2009 caravan
Anyone know how to enable the rear speakers in a 2009 Caravan CV through Starmobile. 2 different dealers tried & failed.
Old Jul 16, 2010 | 11:14 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Have you had the van ck for codes in the audio system? Here are some codes that may help you.
RADIO
Diagnosis and Testing
B1401-FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT LOW
B1402-FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B1403-FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1405-FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT LOW
B1406-FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B1407-FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1409-REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT LOW
B140A-REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B140B-REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B140D-REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT LOW
B140E-REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B140F-REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1421-AUDIO CD READ ERROR/INOPERABLE DISC
B1422-AUDIO DVD READ ERROR/INOPERABLE DISC
B1429-RADIO DISPLAY HIGH TEMPERATURE
B142A-RADIO UNIT HIGH TEMPERATURE
B142D-AUDIO ANTENNA NOT CONNECTED
B142E-GPS ANTENNA NOT CONNECTED
B142F-SATELLITE RADIO ANTENNA NOT CONNECTED
B1430(2.5)-SATELLITE RADIO ANTENNA INTERNAL PERFORMANCE
B1430(4.0)-SATELLITE RADIO ANTENNA INTERNAL PERFORMANCE
B143B-MICROPHONE 1 CIRCUIT LOW
B143C-MICROPHONE 1 CIRCUIT HIGH
B143E-MICROPHONE 2 CIRCUIT LOW
B143F-MICROPHONE 2 CIRCUIT HIGH
B1492-GENERAL MICROPHONE PERFORMANCE
B14B7-MICROPHONE 1 CIRCUIT OPEN
B14B8-MICROPHONE 2 CIRCUIT OPEN
B156B-SATELLITE RADIO ANTENNA CIRCUIT
B221E-RADIO INTERNAL
U0010-CAN INTERIOR BUS
U0011-CAN INTERIOR BUS OFF PERFORMANCE
U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE (TOTALLY INTEGRATED POWER MODULE) (TIPM)
U0155-LOST COMMUNICATION WITH CLUSTER/CCN
U0159-LOST COMMUNICATION WITH PARKING ASSIST CONTROL MODULE (PTS)
U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIN)
U0186-LOST COMMUNICATION WITH AUDIO AMPLIFIER (AMP)
U0187-LOST COMMUNICATION WITH DVD PLAYER (DVD)
U0196-LOST COMMUNICATION WITH VEHICLE ENTERTAINMENT CONTROL MODULE -
Old Jul 17, 2010 | 07:10 AM
mdunlop's Avatar
mdunlop
Thanks for the DTCs. However, I believe there are no DTCs because the stock RES radio is functioning as intended. The rear speakers don't work because the ECU via can bus is telling the radio it doesn't have rear speakers.The vehicle (CV) came from the factory without rear speakers but has the complete (including rear spreakers)speaker harness. I installed the proper impedance rear speakers and read 4 ohms on the pins of the radio harness connector C2. My research suggests the rear speakers enable/disable command is stored in the ECU and can only be modified with Starmobile by a Dodge dealer with dealer connect. 2 dealer techs told me they did not see the option in the Starmobile list of customer preferences & gave up. I wasn't charged. Process of elimination leaves the Starmobile vehicle preparation page list or flashing the ECU. My intention is to find the proper process and relay it to a dealer tech so he won't get side tracked by other issues.
Thanks,
Mike
Old Aug 26, 2021 | 05:16 AM
Federico Caprotta's Avatar
Federico Caprotta
I just bought that same year CV Dodge Caravan did you ever figure out how to make the rear speakers wires active?
