Auxiliary Transmission Cooler Question
Old Jul 23, 2010 | 09:19 PM
David Stembridge's Avatar
David Stembridge
Default Auxiliary Transmission Cooler Question
after hitting a deer last month, I had to replace the radiator and fan assembly... among a few body parts. I noticed that the van had an Auxiliary Transmission Cooler on the front side of the AC Condensor. I don't believe that my van had lines going through it though. I believe it just ran lines into the nipples on the radiator. Picture below is the old radiator, new one looks identical (picture at bottom)
Oh, it's a 2000 Dodge Grand Caravan.
Is there a special means of connecting the Auxiliary Cooler? Special hoes? or just a standard hose?
Last edited by David Stembridge; Jul 23, 2010 at 09:21 PM. Reason: forgot van info....
Old Jul 23, 2010 | 10:30 PM
sapporo's Avatar
sapporo
you can just ignore it or install if you want. all you need is 5/16" high pressure hoses (NOT regular fuel line).
Old Jul 23, 2010 | 11:01 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would install new lines for the trans cooler. It will help to keep the fluid from getting too hot.
Old Jul 23, 2010 | 11:09 PM
sapporo's Avatar
sapporo
only if it's connected correctly
