Does 2002 3.8L have fuel pressure test port?
Old Jul 24, 2010 | 11:28 AM
2002caravan's Avatar
2002caravan
Default Does 2002 3.8L have fuel pressure test port?
I can't find one and the manual says the fuel relief procedure is to pull the pump relay and run it out of gas. I'm starting to think it doesn't have one.
Old Jul 24, 2010 | 11:37 AM
sapporo's Avatar
sapporo
yes, it has a fuel pressure test port
Old Jul 24, 2010 | 11:52 AM
2002caravan
where?
I looked for a while. I think you have to have the right kit or rig something between the fuel line/fuel rail connection.
Old Jul 24, 2010 | 12:41 PM
sapporo's Avatar
sapporo
service manual says to connect pressure gauge to test port on injector rail. that's what the book says.
Old Jul 24, 2010 | 01:28 PM
2002caravan
Hmmmm... I'm really hoping it exists but I've looked and looked. I watched a couple 01+ mopar videos where they needed to connect between the line and rail but nothing close enough to be specific to my model.
Old Jul 24, 2010 | 04:53 PM
master tech's Avatar
master tech
Site Moderator & Tech
On some dodge vans there is a test port as part of the fuel line. Now if you don't have a test port,Then you need to remove the line and if you have the adapter to hook up your fuel gauge.
Old Jul 24, 2010 | 05:11 PM
905ranger's Avatar
905ranger
Maybee this can help.
Old Jul 24, 2010 | 09:05 PM
2002caravan
Yup it did. I have a little metal cap in that spot. It is definitely not a test port. Looks like this rig doesn't have one. Didn't find one on the fuel line either. It looks like I need to unhook the fuel line and use an adapter.
Old Jul 24, 2010 | 10:09 PM
2002caravan
Problem found. With my hands tied on the fuel delivery issue I started poking around and found an oil fouled MAP sensor. The PCV went and now the intake is coated in oil.
