Misfire - Codes P306 and P303
Old Jul 25, 2010 | 02:52 PM
pherdog's Avatar
pherdog
Default Misfire - Codes P306 and P303
I have about 85,000 miles on my Dodge Grand Caravan Sport with the 3.8L engine. I changed the spark plugs and wires about a week ago. After I replaced them, the vehicle ran great. Now, one week later, I am getting a misfire on cylinder 3 and 6. Any idea what might be causing it? Or how to diagnose it? Thanks in advance....
Old Jul 25, 2010 | 06:31 PM
master tech's Avatar
master tech
Site Moderator & Tech
Did you replace the spark plug wires too?
Old Jul 25, 2010 | 08:45 PM
sapporo's Avatar
sapporo
looks like he did replace the wires.
This is where I'd connect an scanner and read misfire and/or a scope to read ignition pattern
Old Jul 25, 2010 | 08:58 PM
master tech
Sorry........ I would ck the wires for a good connection. And recheck the gap on the spark plugs and maybe do a compression test on the number 3 and 6 cylinders.
Old Jul 28, 2010 | 01:11 PM
pherdog's Avatar
pherdog
The problem ended up being a bad wire in a wiring harness causing the misfire. In case anyone was interested........
Old Jul 28, 2010 | 01:25 PM
sapporo's Avatar
sapporo
what wire?
it's sure nice to know when the problem is solved. most users demand an answer in a panic then never get back to what the solution was.
Old Apr 15, 2024 | 11:41 AM
andy_huber's Avatar
andy_huber
Same issue. Can you tell me how much of the wiring harness you replaced?
