Fuel pump relay
Old Jul 25, 2010 | 11:23 PM
dodgeforce39's Avatar
dodgeforce39
Default Fuel pump relay
2000 dodge caravan 3.0 are the relays by the battery interchangeable. I want to swap the fuel pump relay with another to see if the relay is not my problem. I disconnected the fuel line and turned the key on and no gas comes out of the line.
Old Jul 26, 2010 | 12:28 AM
sapporo's Avatar
sapporo
all relays that look the same, in the PDC, will interchange.
Old Jul 26, 2010 | 08:44 PM
master tech's Avatar
master tech
Site Moderator & Tech
You may want to ck the ASD relay too. Also ck the fuel pump relay for power and ground with a 12 volt test lite or a DVOM. Also ck all the fuse's too.
Old Jul 27, 2010 | 07:04 AM
dodgeforce39
Yea i check power at the fuel pump relay and felt them and they seem to
be working ok. I disconnected power at the fuel pump checked ground with a volt meter and checked and it had power when the key is turned but no sound at all from the pump.
Old Jul 27, 2010 | 10:22 AM
sapporo's Avatar
sapporo
maybe a bad pump?
Old Jul 27, 2010 | 10:48 PM
dodgeforce39
Smile
Fuel pump it is..........
