2008 overheating with air conditioning on
Old Jul 28, 2010 | 06:19 PM
jasminerobinson's Avatar
jasminerobinson
Default 2008 overheating with air conditioning on
had driven about 10 blocks, it's 35 degrees out, turn on the air conditioning and seconds later temp. gauge showed engine was overheating, and hot air was coming out of the air conditioning vents.
does this happen to anyone else?
Old Jul 28, 2010 | 08:09 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
might check fuses, might be fans not operating?
Old Jul 28, 2010 | 09:36 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
It could many things,ck the coolant level and a pressure test. Here are some things,water pump,radiator,thermostat stuck closed, or heater core.And like dodgecaravan2010sxt had said,cooling fans.
