Smoke from engine hood
Old Aug 3, 2010 | 02:32 PM
amdcdm's Avatar
amdcdm
Default Smoke from engine hood
Hai!
I saw smoke coming form the engine hood this morning in my Grand Caravan (3.8 L) 1997 model. My AC compressor wasnt working for a while. I have not used the AC either. However, when I opened the hood, saw that there is some smoke coming from belt near to the coolent holder (passenger side). The belt was burned a bit and gave the rubbery smell. Towed the vehicle to a mechanic and he said the compressor needs to be changed as it has frozen. Will this be the reason or is it just that the belts are worn out and dosent move well.
Help me posting your view. Thanks.
Old Aug 3, 2010 | 03:06 PM
Tizzy1's Avatar
Tizzy1
Welcome to the forum. I would assume the compressor has siezed. It is on top of the engine, you should be able to grab the clutch and turn it. If the bearing for the pulley crapped out, you should be able to see that with the engine running.
Old Aug 3, 2010 | 04:07 PM
amdcdm's Avatar
amdcdm
Default Thanks
Thanks for the suggestion. I was wondering if by changing this compressor, my AC will start cooling (with the gas and all other stuff being in). What would it cost like?
Will this also affect my clutch system?
Old Aug 3, 2010 | 05:09 PM
Tizzy1's Avatar
Tizzy1
Have you ever had a/c work done to the vehicle?? What do you mean by "clutch system"?
Old Aug 3, 2010 | 05:47 PM
amdcdm's Avatar
amdcdm
No I have not done any work on the AC system.
I read about some compressor clutch and that was what I mentioned.
Old Aug 3, 2010 | 07:28 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
i beleive if clutch seized i bet ya got to replace the whole compressor as a unit. that means removal of the refrigerant and then recharge.
Old Aug 3, 2010 | 08:35 PM
trophyslayer's Avatar
trophyslayer
I had the compressor done on my jeep due to the clutch seized up, also had the dryer replace since the system was opened, cost alot due to the cost of parts, total was 750 plus tax, 1year warranty,but yours probably will be a bit higher due to needing a new belt, and I would recommend a new belt tensioner assembly too,
make sure the warranty is not just for parts but for labor too, I had called 7 shops, only one would warranty both parts and labor
Old Aug 4, 2010 | 11:55 AM
amdcdm's Avatar
amdcdm
Yes, the clutch was frozen and had to replace the whole compressor, replace gas etc. Costed me 285 for the parts and 195 for labor. Joy autos at Diamond Bar (CA) did a good job. I spoke with others who were asking for just double the money.
Yes, he did mention that the fan belt tensioner is getting old, but he said it can wait.
Thank you all for posting your view.
Old Aug 4, 2010 | 02:19 PM
Tizzy1's Avatar
Tizzy1
Odds are pretty good that your evaperator is leaking and the low system charge is what caused the compressor to fail. The evaperator is easy to check, you just lower the glove box and remove the large grommet that is in the heater housing that is for the evaperator temp probe. You can look right in at the evaperator and if it's leaking, you'll be able to tell.
Old Aug 13, 2010 | 05:49 PM
amdcdm's Avatar
amdcdm
10 days after changing the compressor, my AC blows hot air, went to the same mech and he says everything looks ok, but the acctuator is gone and thats the reason its not working....... he says it will cost 130+ labor. Just can't believe what's happening here. can some one explain me.
