'00 Grand Caravan Rear Blower Issues
Old Aug 10, 2010 | 01:45 PM
tsenior's Avatar
tsenior
Unhappy '00 Grand Caravan Rear Blower Issues
My mechanic replaced the swtich thingy that controls the hot/cold air that blows through the rear vents. It's been less then a year and now the rear only blows non-a/c air. The A/C in the front is working great.
Is the switch thingy the root cause or is it something else? Is this a known issue? Is this someting I can replace myself? I'm trying to avoid having pay $$$ without knowing what the root cause is. Any suggesstions?
Thank you,
tsenior
Old Aug 10, 2010 | 03:31 PM
Tizzy1's Avatar
Tizzy1
does it do the same thing when controlled from the front controls??
Old Aug 11, 2010 | 01:27 PM
tsenior's Avatar
tsenior
It does the same thing via front controls.
Old Aug 11, 2010 | 01:50 PM
Tizzy1's Avatar
Tizzy1
up in the DIY sticky, there is a cut and paste from the service manual for doing an actuator test / calibration of the hvac system. Try that and see if you get any codes. If you have a bad actuator it should show up with the test.
Old Aug 30, 2010 | 01:57 PM
tsenior's Avatar
tsenior
Tizzy,
What/where is the DIY Sticky? Is the acutator the motor that controls heat/cold air? Will it show me a 'Check Engine' light or do I need a computer when I do this?
Thanks,
-T
Old Aug 30, 2010 | 10:08 PM
master tech's Avatar
master tech
Site Moderator & Tech
You will find the DIY sticky at the top of page,under Tizzy and other DIY.
Old Aug 30, 2010 | 10:14 PM
hemi4spd's Avatar
hemi4spd
senior
ist a comination of pushing buttons on the heater controls and observing the light flash on the rear wiper button. counting flashes = numbers.
