2000 Caravan Transmission Hoses
Old Aug 13, 2010 | 08:48 PM
dodgeforce39's Avatar
dodgeforce39
Default 2000 Caravan Transmission Hoses
There are two hoses that run up to the radiator to cool the fluid. One of them is seeping out fluid. It I replace the hose is there anything I need to do when I fill the fluid back up. Will there be air in the line I have to bleed?
Second what's the correct way to check my fluid level for the trans?
Old Aug 13, 2010 | 10:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
FLUID LEVEL AND CONDITION CHECK
NOTE: Only transmission fluid of the type labeled Mopar ATF+3 (Automatic Transmission Fluid - Type 7176) should be used in this transaxle.
FLUID LEVEL CHECK
The transmission sump has a fluid level indicator (dipstick) to check oil similar to most automatic transmissions. It is located on the left side of the engine. Be sure to wipe all dirt from dipstick handle before removing.
The torque converter fills in both the P Park and N Neutral positions. Place the selector lever in P Park to be sure that the fluid level check is accurate. The engine should be running at idle speed for at least one minute, with the vehicle on level ground. At normal operating temperature (approximately 82 C. or 180 F.), the fluid level is correct if it is in the HOT region (cross-hatched area) on the oil level indicator Fluid Level Indicator Markings The fluid level will be approximately one-quarter inch above the lower hole of the dipstick at 70° F fluid temperature
FLUID LEVEL CHECK USING DRB
NOTE: Engine and Transaxle should be at normal operating temperature before performing this procedure.
Start engine and apply parking brake.
Hook up DRB scan tool and select transmission.
Select sensors.
Read the transmission temperature value.
Compare the fluid temperature value with the chart.
Adjust transmission fluid level shown on the dipstick according to the chart.
Check transmission for leaks. Transmission Fluid Temperature Chart
Low fluid level can cause a variety of conditions because it allows the pump to take in air along with the fluid. As in any hydraulic system, air bubbles make the fluid spongy, therefore, pressures will be low and build up slowly.
Improper filling can also raise the fluid level too high. When the transaxle has too much fluid, the gears churn up foam and cause the same conditions which occur with a low fluid level.
In either case, air bubbles can cause overheating and/or fluid oxidation, and varnishing. This can interfere with normal valve, clutch, and accumulator operation. Foaming can also result in fluid escaping from the transaxle vent where it may be mistaken for a leak.
FLUID CONDITION
Along with fluid level, it is important to check the condition of the fluid. When the fluid smells burned, and is contaminated with metal or friction material particles, a complete transaxle recondition is needed. Be sure to examine the fluid on the dipstick closely. If there is any doubt about its condition, drain out a sample for a double check.
MoparŽ ATF+3 (Automatic Transmission Fluid-Type 7176) when new is red in color. The ATF is dyed red so it can be identified from other fluids used in the vehicle such as engine oil or antifreeze. The red color is not permanent and is not an indicator of fluid condition. As the vehicle is driven, the ATF will begin to look darker in color and may eventually become brown. This is normal. A dark brown/black fluid accompanied with a burnt odor and/or deterioration in shift quality may indicate fluid deterioration or transmission component failure.
After the fluid has been checked, seat the dipstick fully to seal out water and dirt.
