just bought 94 dodge caravan-need radio help
Old Aug 14, 2010 | 02:47 AM
jmysr's Avatar
jmysr
Default just bought 94 dodge caravan-need radio help
After 250,000 miles on my Voyager(3.3 Auto)I finally put it to rest and found a sweet 94 caravan w/150,000 mi(3.3 auto) for $700.00 but the radio is the infinity radio & there is no manual for it. Does anyone know how to set the clock-it is different from voyager & I haven't been able to figure the correct procedure to set time. Thanks in advance for any help!!
Old Aug 14, 2010 | 09:50 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the Caravan section,
FF
Old Aug 14, 2010 | 03:45 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Can you post a picture of the deck. Its been a while, but once i ca see the deck it should come back to me.
Old Aug 15, 2010 | 08:38 AM
BenHertz's Avatar
BenHertz
From the Chrysler Sound System manual:
Clock setting procedure - Radios WITHOUT GRAPHIC EQUALIZER
To start the procedure, the radio display must be showing the time. If the radio frequency is being displayed, press the SEL button to activate the time display.
1. Press the SET button and "P" will be displayed.
2. Press the SEL button and the hour will be displayed.
3. Rotate the tuning **** to change the hour setting.
4. Press the SEL button again to display minutes.
5. Rotate the tuning **** to change the minute setting.
6. Press the SEL button once again to complete the procedure.
Clock setting procedure - Radios WITH GRAPHIC EQUALIZER
1. Using the point of a ballpoint pen or similar object, press either the hour (H) or minute (M) buttons on the radio. The display will show TIME.
2. Press the H button to set hours or the M button to set minutes. The time setting will increase each time you press a button.
3. Press any other button to exit from the clock setting mode.
Old Aug 15, 2010 | 05:06 PM
master tech
Thank you BenHertz.
