Blower motor schematic or photos or parts fiche ? 1999
I have a Haynes manual for the Caravan that I have 1999 15th Anniv. Millenium model but no pix of where exactly the motor sits or fits or can be taken out. I dont want to start pulling more stuff off than necessary . I did check the voltage to the motor and that is good so quite sure that the motor is the problem.
I need pix. Not afraid to break a tab or two to get it out ... probably some glue or epoxy would seal it well if I had to do that .. I just want to see a pix
Any pix
Any pix
BLOWER MOTOR AND WHEEL ASSEMBLY
REMOVAL
Remove glove box. Refer to Instrument Panel and Systems.
Remove (4) hex head screws to blower motor cover Blower Motor Cover
Disconnect blower motor wiring.
Remove grommet for wiring Wiring Grommet Feed wiring through blower housing Feeding Wiring Through Housing
Remove mounting screws for blower motor Blower Motor Screws
Allow the blower assembly to drop down, and remove assembly from vehicle.
INSTALLATION
For installation, reverse the above procedures.
REMOVAL
INSTALLATION
