Code help please.
Old Sep 5, 2010 | 05:07 PM
96grand's Avatar
96grand
Default Code help please.
My wifes has a 96 Grand Caravan with a 3.8 engine. The check engine light came on and I need help with the code. First, Autozone ran the codes and told me there was a turbine issue and a first gear error. However, I didn't notice any transmission issues. I cleared the codes, but the light came on within a couple miles. I went back to Autozone and they told me there were no codes. I did the key on test to get codes both times the check engine light came on and came up with 12-21-55. Any help would be appreciated. Thank you.
Old Sep 5, 2010 | 07:34 PM
sapporo's Avatar
sapporo
do a google search for chrysler diagnostic code 21. you'd be amazed at what you find. it took me 10 seconds to do this for you to find 21 is related to oxygen sensor, which makes sense with how the light comes on in a few minutes. Oxygen sensors take a little time to come online after a start.
if you don't like my answer or autozones quality diagnostic process, have a real mechanic fix your van.
Old Sep 5, 2010 | 11:19 PM
master tech's Avatar
master tech
Site Moderator & Tech
Code 21 is the upsteam o2 stays center.
Old Sep 5, 2010 | 11:26 PM
96grand's Avatar
96grand
Thanks for the help. I did a search on this site and didn't find it.
Old Sep 5, 2010 | 11:38 PM
96grand's Avatar
96grand
What is "stays center"? Does that mean the O2 is bad? Thank you.
Old Sep 5, 2010 | 11:50 PM
master tech
Yes there is.You have an upsteam and one downsteam o2 sensor.
