2001 caravan door adjustment
Old Sep 5, 2010 | 06:56 PM
wattum's Avatar
wattum
Default 2001 caravan door adjustment
My 2001 caravan has the lowered floor by Braum (handicapped) with the folding ramp mounted in the passenger side door. Everything works great with the exception that once in a while it will almost close and then open back up again. Like it is hitting something, at one point. With the door in the open position, if I slightly lift the door upward at the door handle, then the door will operate properly every time. It seem that there must be some sort of adjustment that I could make to correct this. hopefully someone has a DIY fix for this.
Old Sep 5, 2010 | 11:24 PM
master tech's Avatar
master tech
Site Moderator & Tech
SLIDING DOOR ADJUSTMENTS
NOTE: For power sliding door procedures refer to POWER SLIDING DOOR SYSTEM in the ELECTRICAL section.
PRELIMINARY CHECKS
Close the sliding door, visually checking C-post striker alignment entry into latch. Striker at this point must not affect alignment. Striker should go straight into the latching mechanism.
On vehicles with left sliding doors, check the fuel door blocker striker entry into latch. Striker at this point must not affect alignment.
Check C-post and B-post for door to aperture gaps and door to door gaps. All gaps should be 5 mm ± 1 mm.
Check door for height using character lines as a reference. Also check roof contour as a controlling factor.
Using the procedures noted below, adjust the side door in the order the individual steps are called out.
DOOR FLUSHNESS ADJUSTMENT
Check sliding door flushness at the C-pillar striker.
Adjust the C-pillar striker in or out until the door is flush.
Check upper B-pillar flushness to A-pillar cover.
Loosen one nut on upper hinge and adjust door in or out until the door is flush.
Check flushness at upper C-pillar.
If upper C-pillar flushness is out of specification use a heavy rubber mallet on the door assembly until door is in specifications.
DOOR GAP ADJUSTMENT - UP/DOWN
Visually inspect the sliding door for fitting low at the top of the door by checking the alignment of the top contour of the door to the quarter panel.
Fully open the sliding door.
Verify that all center hinge bolts are tight.
Adjust the rear of the sliding door up by turning the center hinge bolt clockwise (SLIDING DOOR CENTER HINGE).
Close the door and check the sliding door alignment.
Adjust the front of the sliding door up by adjusting lower hinge bolts.
Open door half way and remove lower hinge bolt access plug.
Loosen bolts as necessary to move the front of door up or down.
Check the upper hinge for possible bind, adjust as necessary.
Fully open door and apply thread lock nut onto the center hinge bolt. Tighten nut until till it butts up against the welded nut on the center hinge. Tighten nut to 15 N·m (130 in. lbs.). It may be necessary to hold the center hinge bolt to prevent it from turning while tightening nut.
Verify alignment, adjust as necessary.
DOOR GAP ADJUSTMENT - FORE/AFT
Check height of sliding door at the B-post and C-post to determine which area is contributing the greatest to the incorrect gaps.
If the sliding door is high at the C-post;
Open the door to mid-point of travel.
Mark outline of center hinge on sliding door to assist in making adjustments.
Loosen center hinge bolts (SLIDING DOOR CENTER HINGE).
Move hinge fore or aft to position the sliding door into the correct location.
Tighten center hinge bolts.
If the sliding door is low at the B-post;
Remove access plug in the sliding door trim panel.
Mark outline of lower roller arm bracket on sliding door to assist in making adjustments.
Loosen lower roller arm bracket bolts (SLIDING DOOR LOWER ROLLER ARM).
Move hinge downward to raise the door.
Tighten lower roller arm bracket bolts.
If the sliding door is low at the C-post;
Adjust the adjustment bolt up or down to move the door position. (SLIDING DOOR CENTER HINGE).
Verify alignment adjust as necessary.
If the sliding door is high at the B-post;
Move hinge upward to raise the door.
DOOR SEAL COMPRESSION
First check Gap & Flush. Check seal compression near the middle of the door even with the latch assembly. Using a piece of paper, place it across door seal and close door. Pull paper out of door opening. If paper tears setting is to tight, if paper slides thought to easily the compression is insufficient and needs to be adjusted.
Adjust seal compression at the top of the B-post seal;
Open door to mid-point of travel.
Mark outline of upper roller arm on door to assist in making adjustments.
Loosen bolts attaching upper roller arm to door (SLIDING DOOR UPPER STOP).
Decrease the length of the upper roller arm to increase seal compression.
Increase the length of the upper roller arm to decrease seal compression.
Tighten all upper roller arm bolts.
Verify door alignment, adjust as necessary.
Adjust seal compression at the bottom of B-post seal.
Mark outline of lower roller arm on lower roller arm bracket to assist in making adjustments (Sliding Door Lower Roller Arm).
Loosen bolts holding lower roller arm to lower roller arm bracket.
Pivot lower roller arm toward center of vehicle to decrease seal compression.
Pivot lower roller arm outward to increase seal compression.
Tighten lower roller arm bolts.
NOTE: Adjusting seal compression at the B-post can affect door flushness the C-post.
STABILIZER ADJUSTMENT - UPPER/LOWER
Open sliding door.
Loosen the bolts holding the male stabilizers to the sliding door enough that the stabilizers can move with some effort.
Close and then reopen sliding door.
Tighten all stabilizers bolts.
