2002 Dodge Caravan stalling?
Old Sep 30, 2010 | 02:59 PM
Tinkerbellfan's Avatar
Tinkerbellfan
Question 2002 Dodge Caravan stalling?
I have been on the threads trying to find out before posting another stalling question, but none seem to be the same as mine. So here goes...
Recently, 3 weeks, my van has been feeling different while driving. A hiccup if you will is noticed while driving along, no speed in particular or weather condition. Now within the last week it stalls after starting when I put into D or R. It starts right up again and is a little rough on the drive. Today it has become worse, and just stalled while sitting at a light. It's driving me crazy as within the last 6 months I have had several things done to it. All new plugs and ignition wire set, new brakes and drums, new air filter, gas filter, coolant flush, new thermostat, new evap line. Don't know if I should sink anymore into the van as it is old, but it usually runs well. Had it to the shop 2 weeks ago and they didn't know what was wrong with it, as it was intermittent and now it more constant.
Any help would be appreciated.
Old Oct 1, 2010 | 10:10 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
When you have a problem,post at anytime.There has been a problem with wire harness around the power reservoir. See if the harness is soaked with oil,and you may need to open the harness to ck the wires.
Old Oct 2, 2010 | 08:08 AM
Tinkerbellfan
Thanks - it's at the shop and they have no idea what the problem is. No codes are showing so they had it overnight and hopefully today they may have it solved ???
