[4th Gen : 01-07]: 2005 Caravan Intermittent Heater Problem
Old Oct 6, 2010 | 08:46 PM
gtdurango's Avatar
gtdurango
Default 2005 Caravan Intermittent Heater Problem
The heater in my '05 Grand Caravan sometimes blows hot and sometimes blows cool. It hasn't overheated and the temp gauge has remained pretty consistent (right in the middle between H and C). I haven't seen any coolant leaks. I've read some posts for similar problems that suggest it could be a bad thermostat, but wouldn't that cause it to overheat?
Has anyone had this problem?
Thanks
Old Oct 6, 2010 | 09:19 PM
master tech's Avatar
master tech
Site Moderator & Tech
It could be the thermostat. I had a problem like that. The heater worked fine until i started driving, and then it would be cooler. Replaced the t-stat and the heater worked fine. The reason was the t-stat was sticking in an open position.
Old Oct 7, 2010 | 09:03 PM
gtdurango's Avatar
gtdurango
Thanks. So the thermostat can be bad even though it's not overheating?
Old Dec 17, 2013 | 06:49 PM
thetuttleandy2003's Avatar
thetuttleandy2003
Default my 2005 grand carvan have blows cold air then blows hot for 2 mins thn blows cold aga
I replaced everything n I still have have hardly any heat the heat gaguge goes up n dwn start to go to over heating but then drops down to the 3rd red line then goes back down and still has no heat
