2005 Dodge caravan 3.3 engine swap
Old Oct 17, 2010 | 08:26 PM
nop85's Avatar
nop85
Default 2005 Dodge caravan 3.3 engine swap
Hi, I have searched the forum and i can't find a definitive answer.
i have a 2005 Dodge caravan 3.3 with 200 000 miles, the transmission is about to die so i spotted a few wrecked 2001-2004 caravans with the same engine/trans. setup. I understand that between 2001-2004 and 2005-2007 there is a big change with the ecm/pcm etc..
the big question is, can a 2001-2004 engine/trans. work properly in a 2005 van? do i have to swap all the sensors, swap everything that have a sensor/electrical connection from the 2005?
i'd like to swap the whole engine/trans. together no mix and match of part if possible.
thank you.
Old Oct 17, 2010 | 11:08 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
2001 thru 2007 are the same body style. Same engine and transmission. Hope this helps.
Old Oct 18, 2010 | 04:55 PM
Tizzy1's Avatar
Tizzy1
EGR is different 01 - 04 and 05 and newer, you may need to swap that.
Old Oct 18, 2010 | 04:59 PM
Tizzy1's Avatar
Tizzy1
The crankshaft sensor also appears to be different 01 -04 and 05 and newer
Old Oct 19, 2010 | 04:08 PM
nop85's Avatar
nop85
thanks, i will have the donor car in two weeks, i'll update the thread with what i had to swap etc.
