2002 Dodge caravan p1388
Old Oct 23, 2010 | 08:38 PM
budguy's Avatar
budguy
Default 2002 Dodge caravan p1388
My van cranks over but won't start. Checked for spark none. Checked 4 wires to coil for power and won't light a test light on any, key on or turning over.
Doing the key bump I get p1388 code. Checked and replaced asd relay with a working one from fuse panel. Checked under fuse panel. Found a corroded wire and replaced the bad spot. Checked still no spark. Had a look at all other wires and not seeing any other bad ones.
Checked connections to computer beside the battery and no corrosion in or around plug-ins. Wires to the computer all look clean and good. On the left frame rail there's a computer, transmission computer? Does this one have anything to do with spark or the asd relay code I get?
Any suggestions or advice please!
Old Oct 23, 2010 | 10:01 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
The ASD can be difficult to diagnose. It powers MANY things, If you don't have access to a meter and diagrams, it's gonna be tough to find it unless you get lucky. Since you mentioned 4 coil wires I will assume it's a V-6.
Possible Causes.
ASD RELAY INTERMITTENT OPERATION
INTERMITTENT CONDITION
FUSED B+ OUTPUT CIRCUIT
ASD RELAY
IPM FUSE & RELAY CENTER
ASD RELAY CONTROL CIRCUIT OPEN
ASD RELAY CONTROL CIRCUIT SHORT TO GROUND
PCM
Old Oct 23, 2010 | 10:06 PM
sapporo's Avatar
sapporo
test for power at the asd? try jumping the asd terminals and see if power shows to the coil?
Old Oct 24, 2010 | 12:59 PM
budguy's Avatar
budguy
Default Asd
Haven't tried jumping it, How do I go about trying that?
Old Oct 24, 2010 | 01:03 PM
budguy's Avatar
budguy
oh and yes it's a 6 cyl 3.3l 220000 kms forgot to mention.
Old Oct 24, 2010 | 05:23 PM
sapporo's Avatar
sapporo
paper clip is how I'd jumper the relay
Old Oct 27, 2010 | 04:30 PM
budguy's Avatar
budguy
tried jumping the asd, no fire to coil. The bottom of the fuse center had a really corroded plug, there was power to this plug though. I cleaned it up and still the same no fire. There also was a corroded wire that I replaced. Checked for volts @ the relay and there doesn't seem to be any. This should have some voltage in the 4/5 clips where the asd relay plugs in?
Old Oct 27, 2010 | 06:55 PM
sapporo's Avatar
sapporo
have you checked continuity between the ASD and the coil?
Old Oct 28, 2010 | 02:37 PM
budguy's Avatar
budguy
The third wire on the coil (brown/white) to the connector (30) where the asd relay plugs in has continuity (turns from 1 to 0) sorry new to this but a quick learner.
Old Oct 28, 2010 | 03:20 PM
budguy's Avatar
budguy
Put power to the brown and white wire on the coil and the van starts, runs rough but starts, what are your thoughts now? I'm still lost :/
