2001 caravan flickering headlight/ single speed blower fan
I have an 2001 dodge caravan with the 3.3, and 145,000 miles. The front blower motor only runs on high, and I can live with that. But I have noticed that when i have the power switch on to the heat/cool/fan console and have the fan switch on anything but high my headlights flicker ever so slightly.. so do you guys think its a bad motor or switch? or something else?
thanks
thanks
Here is a TSB that may help with the headlamps,and replace the fan blower resistor.
SUBJECT:
Flash: Digital Displays Flicker
OVERVIEW:
This bulletin involves reprogramming the Body Control Module (BCM).
MODELS:
2001 - 2002 (RS) Town & Country/Caravan
2001 - 2002 (RG) Chrysler Voyager
NOTE: **THIS BULLETIN APPLIES TO VEHICLES BUILT BEFORE 0CTOBER 1, 2001.**
NOTE: **IF SB 08-19-02 WAS PERFORMED ON A VEHICLE, THE BCM SOFTWARE
WAS REVISED TO 04836965AE. THIS MAY RESULT IN THE FOLLOWING ON 2001 AND
2002 VEHICLES: VEHICLE THEFT ALARM (VTA) LAMP INOPERATIVE, VEHICLES
EQUIPPED WITH A (RAS) RADIOS WILL HAVE NO DAYTIME BRIGHTNESS,
AND THE BCM MAY NOT POWER DOWN WHEN THE IGNITION KEY IS TURNED
OFF. SB 08-019-02 REV. A NEEDS TO BE PERFORMED ON THOSE VEHICLES
WHICH WILL REVISE THE BCM SOFTWARE TO 04833855AD.**
SYMPTOM/CONDITION:
When the dimmer control wheel is set at maximum brightness, just below the parade mode
(daytime brightness) position, the Vacuum Fluorescent (VF) displays for the odometer,
transmission range indicator (premium cluster), Electronic Vehicle Information Center
(EVIC) or overhead console, radio and Automatic Temperature Control (ATC) may flicker
between maximum brightness and daytime (parade mode) brightness.
NOTE: THERE ARE NO BCM FAULT CODES FOR THIS CONDITION.
08-019-02 REV. A -2-
DIAGNOSIS:
**If the customer complaint matches the Symptom/Condition, the vehicle was built before
October 1, 2001 (MDH 1001XX), and the BCM software is NOT p/n 04833855AD, OR
SB 08-019-02 was previously performed, perform Repair Procedure.**
EQUIPMENT REQUIRED:
NPN Battery Charger
CH6000 Scan Tool (DRB III®)
CH7035 General Purpose Interface Bus Cable (GPIB)
CH7000/7001 J1962 Cable
MDS2 (Mopar Diagnostic System)
REPAIR PROCEDURE:
1. Connect a Battery Charger and set as close to 14 volts charge as possible.
2. Flash reprogram the BCM using the MDS2®, operating at CD 2121 or
higher, and the DRBIII® operating at software release level 55.3 or higher.
The BCM software must be p/n 04833855AD.
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
DIAGNOSIS:
EQUIPMENT REQUIRED:
NPN Battery Charger
REPAIR PROCEDURE:
thanks
thanks
I replaced mines, it fixed it. BUT now its happening again.
