00 GC pass side dash speaker removal ?
Old Nov 16, 2010 | 11:38 PM
Jetmeck2's Avatar
Jetmeck2
Default 00 GC pass side dash speaker removal ?
Infinity sound system. Those that have replaced this chime in here please. How do I get the dash up to access speaker and what will be needed to remove speaker after gaining access ? Am about to do a parts run at my local salvage yard and need to know in advance.
Thanks...............
Old Nov 17, 2010 | 12:50 AM
master tech's Avatar
master tech
Site Moderator & Tech
INSTRUMENT PANEL SPEAKER
INSTALLATION
Remove instrument panel top cover.
Remove screws holding speaker to instrument panel and remove speaker Left Instrument Panel Speaker or Right Instrument Panel Speaker
Remove anti rocking finger screw.
Disconnect wire connector from speaker.
Remove speaker.
INSTALLATION
For installation, reverse the above procedure.
Old Nov 17, 2010 | 06:42 AM
sapporo's Avatar
sapporo
I'm sure I'm wrong but I was told you need to remove the a-pillar trim before attempting to remove the top dash cover. and you also need to check the metal clips on the apillar trim that the clips stay on the trim. if they stuck in the hole you need to remove the clips from the hole and attach to the trim. if you dont, guys say that the trim will not snap back on and probably break the tabs off the trim.
Old Nov 17, 2010 | 10:07 AM
Jetmeck2's Avatar
Jetmeck2
INSTALLATION
Remove speaker.
INSTALLATION
Straight forward as I thought so just pry the top of the dash off ?????
Old Nov 17, 2010 | 10:08 AM
Jetmeck2's Avatar
Jetmeck2
INSTALLATION
Remove speaker.
INSTALLATION
So just pry the top of the dash panel off ??????
Old Nov 17, 2010 | 10:51 AM
jumpdrive2's Avatar
jumpdrive2
Default 00 panel
sorry no pics of a pillar trim
Last edited by jumpdrive2; Nov 17, 2010 at 11:03 AM. Reason: incomplete instructions
Old Nov 22, 2010 | 12:14 AM
tonygross's Avatar
tonygross
this helped me as i just put new speakers in the front.
thanks guys
