cd/tape player removal
Old Nov 25, 2010 | 05:44 PM
jnagraves's Avatar
jnagraves
Default cd/tape player removal
Have a 2007 Grand Caravan. Need to remove the cd player and tape deck. Need some info on how to go about this.
Thanks
Jonathan
Old Nov 25, 2010 | 07:48 PM
sapporo's Avatar
sapporo
remove trim around radio,remove 4 screws, pull out radio assembly, disconnect wires.
Old Nov 26, 2010 | 12:06 AM
master tech's Avatar
master tech
Site Moderator & Tech
Just like sapporo had said, but here is information out of the service manual.
REMOVAL
1. Disconnect and isolate the battery negative cable.
2. Remove cup holder.
3. Remove trim panel above cupholder by pulling straight out.
4. Remove center instrument panel trim panel.
5. Remove screws holding radio to instrument panel.
6. Pull radio rearward to gain access to the back of radio.
CAUTION: Pulling the antenna cable straight out of the radio without pulling on the locking antenna connector could damage the cable or radio.
7. Disconnect the antenna cable by pulling the locking antenna connector away from the radio .
8. Disconnect the wire connectors from the back of the radio.
