no auto choke
Old Dec 8, 2010 | 09:05 PM
temple tapper's Avatar
temple tapper
Default no auto choke
2001 dodge caravan se
i'm from wisconsin and it is about 2 degrees below zero. when i started the van the other morning it started rough and the rpms where at 600. usually they are about 1500 when starting, and its been doing it ever since. i assume there is an automatic choke or something. where should i start? Is there a wire that is common to falling off, corroding? i am use to older chevys with a carb, so i'm kinda at a loss.
thanks
Old Dec 8, 2010 | 09:39 PM
mfahey's Avatar
mfahey
There's no choke with a fuel injected car so you can rule that out. A possibility is the coolant temperature sensor is giving the computer an incorrect reading leading it to think the engine is already warmed up.
Old Dec 8, 2010 | 11:30 PM
master tech's Avatar
master tech
Site Moderator & Tech
The AIS motor may need to be clean or replaced. ( Automatic Idle Sensor).
Old Dec 9, 2010 | 01:01 AM
hemi4spd's Avatar
hemi4spd
lol maybe he means -2 F and at that temp the molasses for oil wouldnt let that spin any faster?
all kidding aside
is it always idling at 600 rpm? even when warmed up?
Old Dec 9, 2010 | 12:56 PM
temple tapper
the thermostat reading on the dash is correct, or is this something different to look at
Old Dec 9, 2010 | 12:57 PM
temple tapper
where is this at, and just some egr valve spray good or no
Old Dec 9, 2010 | 12:59 PM
temple tapper
yes. well around 6 or 700. It doesn't idle up to start. we have -30 wind chills coming this weekend, so I'm hoping to figure this one out tonite. thanks all for the help
Old Dec 9, 2010 | 11:40 PM
hemi4spd's Avatar
hemi4spd
http://
heres where the IAC(AIS) lives, BEWARE!!! if you remove it dont turn it or depress or pull on the pintle, just clean it. You want to put it back in in the same position you removed it.
clean the orfice that it sits in as well with some TB cleaner and a q-tip
Old Dec 9, 2010 | 11:43 PM
hemi4spd's Avatar
hemi4spd
what does the temp gauge on the dash read?
Old Dec 17, 2010 | 12:22 PM
temple tapper
perfect thanks much
