Engine Noise
Engine Noise
Hello out there. I am having a problem with my 2006 Grand Caravan SXT. This van has 84000 miles and have had a Ticking Noise in the Upper part of the engine. If you play with the gas you can make the noise just about go away. But this is a loud noise like a Lifter has no oil pressure. The oil pressure lamp has never come on. The problem is that the Warranty company said the this is a normal problem with this 3.8 with high milage (85000) is not high milage (180000 on my Lexus GS) is high milage. I have yet to find any complanits of this problem on any of the 3.8 that Mopar has put out. The warranty company said that 99% of these engines have a valve train noise that cannot be found upon tear-down,which would leave me holding the bag. Also the Warranty company also said that this noise is a normal sound when the mileage is high. My question to ya'll is HAS ANYONE OUTTHERE HAD OR HEARD OF THIS NOISE,AND IS IT A COMMAN SOUND. It really sounds like BS. I have checked all of the bullitens that have been sent out and have still found nothing. If anyone has any help please let me know.
I have an 06 too, no tick to speak of inless you really really listen hard, so no tick
Question, what type of oil are you using,
if synth you might want to change it out and try regular dino,
( or a little thicker or thinner oil,) not sure which way you want to go, thicker should quite it down, but thinner is better for cold start in cold weather
also did it just start with the cold weather, parked outside?
I recently had a ticking that I thought was a lifter. I replaced the serpentine belt because of mileage. Ticking is now gone and engine is as quite as new.
The belt had been replaced at the Dodge dealer so I assume it was a Mopar belt. It had the V grooves missing for about 3/4 inch in two locations about 180* apart.
Master Tech, I am wanting to know,when your dealership replaced the lifters and still had the noise,did it still have the sound of a bad lifter? That is the thing that is bothering me. The noise sound just like a lifter,but the noise is not that noticable when the engine is cold. As the engine comes up to temperture the noise starts to get louder when it gets hot. I did pull the plug wires on the front of the engine to see if I could change the noise like we use to do to check for a bad rod bearing. But that did not change a thing. I did not test the back Cylinders.I know it sound strange but it almost sounds like this noise can change where it is coming from. Sometimes it sounds like it is coming from the front head and then sometimes it sounds it is coming from the back. I am just about to give up on it.
on
Trending Topics
