Removing Belt Tensioner on 2000 Grand Caravan?
Old 12-24-2010, 02:15 PM
David Stembridge's Avatar
David Stembridge
David Stembridge is offline
Default Removing Belt Tensioner on 2000 Grand Caravan?
Is there a trick to this?
Please advise.....
Thank you very much!
Old 12-24-2010, 04:08 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Hi David
I need to know if you have a 2.4 or a 3.0L motor. I do have pictures for both. If you want them, send me your email address.
Old 12-24-2010, 04:31 PM
Pete M's Avatar
Pete M
Pete M is offline
on my 3.3L I attached a 15mm wrench to a strong 2ft piece of aluminum to give more leverage and make it a bit easier.
also, I recommend a helper to hold up the hood so the prop rod isn't in your way (or do like I did and hook a ratchet strap to the hood and then back to the luggage rack)
Old 12-24-2010, 04:58 PM
David Stembridge
Ok, I got it. Thanks!
Quick Reply: Removing Belt Tensioner on 2000 Grand Caravan?
