Dodge Caravan 3.3 sputter
Codes P1684...P0302. I believe the 1st one means that the batter was disconnected, the 2nd: #2 cylinder miss fire. Plugs and wires should be fine...need someone that knows 3.3s on this one. I'm hoping somebody will come along and save the day!
I know I've been that "somebody" in the past, but I've honestly never worked on a 3.3 (if this was an LA V8...then I would be right at home)
Um, why would you have done a compression test before you had a problem? Why would you negate the suggestion of doing a test now that you have a problem? Basically you're telling the Master that his suggestion of doing this test is useless.
I forget to say what I did a few days ago. Its called CRS, Not to worry. I throw questions out there and see what comes back. If the member already did the compression test, that okay. But my question would be what was the reading? Oh one of those i forgot, There are 3 types of compression test. Did you do just one of them or all of them. 1st is dry, 2nd running and 3rd wet.
I find it odd that the guy did a compression test before this problem came up and now that he has the problem and a Master suggests doing a compression test (one of the most common basic simplest diagnostic test) the OP basicly poo-poo's the thought that he should do a test that was done before the issue arose. I suppose if you had problems breathing, you'd refuse to have a blood pressure test because you just had it done a couple weeks earlier.
Forgive me for dismissing some of the diagnostic processes....when I briefly worked as a service writer at a Chrysler dealer, we would go through the same process, and it kind of frustrated me. RARELY does a plug or a wire randomly go bad on a low mileage, perfect running engine. Valves can have problems, but it's not what I would call common (and it would smoke with a bad valve, right??). 95% of the time, the customer is left with a bill for several things, and still has a problem. I was looking more towards a coil problem or something similar??
when you say an injector code, it would come up in addition to my #2 misfire code?? because I'm not getting any other codes. I really appreciate the help guys, don't get me wrong.
Mopar those are Very valid and respectful responses. I guess it should have been asked to you to develop your rational before casting some sort of judgement upon you. Were all in this together, Help one anothers. I sure do need help from the thoughts others have given me in the past. Way to go Dodge Forum.
