99 GC Sport Running horrid and Flooding plugs
Old Feb 10, 2011 | 05:09 PM
JDohio's Avatar
JDohio
Default 99 GC Sport Running horrid and Flooding plugs
New here and was looking for some help:
Two days ago I was on the highway and traffic was backed up in my lane I had to get in the other lane fast and punched it. It began to accelerate quickly as usual but then almost sounded like I lost a couple cylinders and was missing bad. I could barely keep it at speed. So I pulled off and could barely keep it running. I limped it to a parts store and had the codes check and only reference a bank running rich. I then had it towed home and began to work on it.
Pulled the plugs and found cyl 4 and 6 soaked. Went and got new plugs and wires. Still the same problem. Went and got a New coil pack and still the same problem. I'm at a loss as to what the problem could be But it seems for some reason those two cyl are not firing. Also the plug in cyl 2 is covered in black soot and it was new.
Any help would be appreciated.
Old Feb 10, 2011 | 05:15 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I would do a compression test on all cylinder and post your readings. You could have injectors staying on all the time or something going on with rocker shaft.
Old Feb 10, 2011 | 05:20 PM
JDohio's Avatar
JDohio
Is it possible for two injectors to stick open like this under those conditions.
I unfortunately don't have the ability to to a compression test.
Old Feb 10, 2011 | 05:22 PM
JDohio's Avatar
JDohio
It only seems to load up when I try and run it. I have pulled the plugs and left the plenum off to see if the injectors sprayed while the ignition was on but not trying to start it.
Old Feb 10, 2011 | 06:03 PM
JDohio's Avatar
JDohio
Is it possible for this to jump with a timing chain??
Old Feb 10, 2011 | 07:30 PM
22DODGE22's Avatar
22DODGE22
I've heard (read) a lot about flex plates cracking causing your exact problem.
