one down one to go
Old Feb 15, 2011 | 10:54 AM
ecoli_23's Avatar
ecoli_23
Default one down one to go
got the tranny rebuilt...so now i can drive it again...now my 97 GC we found out that the power steering pressure hose connection on the rack and pinion is stripped and i was told you cant re-tap those....so now i need a new rack and pinion...anyone do this, is it hard to do on my own?
i was thinking...would it be as easy as droppin the rear sub frame to gain access to it?
Old Feb 15, 2011 | 06:02 PM
22DODGE22's Avatar
22DODGE22
How does one go about stripping threads on the high pressure fitting? Once you strip threads, there's no way to tap the hole to make new threads because when you strip the threads, you take metal away so there's nothing left the thread. You'll probably end up replacing the rack.
Old Feb 16, 2011 | 12:38 AM
ecoli_23's Avatar
ecoli_23
yea i got to that point......now i need to figure out if i can drop the rear of the subframe to get at the rack.....
Old Feb 16, 2011 | 04:30 PM
hemi4spd's Avatar
hemi4spd
you only need to remove the cradle plate leave the cradle (subframe) alone see pic
http://
hardest part of this job is punching out the silly roll pin with a hammer and drift
Old Feb 16, 2011 | 05:29 PM
ecoli_23's Avatar
ecoli_23
you dont happen to have a pic of that do you?
Old Feb 16, 2011 | 07:55 PM
22DODGE22's Avatar
22DODGE22
That picture is really wrong. The part that says "steering gear" it pointing at the transmission extension housing!!!
