after market timing belt kit for 99 caravan
hi,every body
newbie in the forum.need help to find good after market timing belt kit and water pump for my 1999 caravan 3.0,any suggestion would be appreciate,
thanks
thanks
Wecome to DF
Get a new tensioner if you didn't get one already.Replace the fan belts and tensioner too. Has the water pump been leaking? If it has you may want to replace the crossover tube and both o-rings. Ck the cam seals for any oil leaks,now would be the time to replace them.
If OEM is too expensive, i know a lot of independent shop mechanic Likes Gates or Dayco for belts and tensioner kit.
As for water pump, I've used Bosch New water pump on few cars, they aren't leaking yet.
stay away from those Re-man/rebuilt water pump!!!
