am i screwed or what?..awd t case noise
Old Mar 8, 2011 | 08:28 PM
bigtbiker's Avatar
bigtbiker
Default am i screwed or what?..awd t case noise
my shop just informed me that my 1997 awd has a transfer case issue...
it makes a noise like al old fashoned u joint going bad...varies with accl/decel.
could it be the cv joint in the center prop shaft near the end of the trans case?...can this vehicle be driven WITHOUT the center propshaft installed, in front drive only? can the awd trans/transfer case be replaced with a two wheel drive trans. converting it to a front drive only?....stuck between a rock and a hard place...180066 miles, zero rust, and runs like new...thanks for your help...BigTbiker
Old Mar 8, 2011 | 09:02 PM
22DODGE22's Avatar
22DODGE22
Yes to all your questions. any of those options will work.
Old Mar 8, 2011 | 10:46 PM
master tech's Avatar
master tech
Site Moderator & Tech
I 2nd the yes. In fact you can disconnect the center drive line at the transfer box and road test the van, This way you will be able to notice if the noise is gone or still there.
Old Mar 15, 2011 | 09:23 PM
bigtbiker's Avatar
bigtbiker
Default Update
heres the poop...transfer case was run dry and the ring and pinion in it ground them selves to death...why?..some dumb *** put atf in the case instead of 90 weight gear oil and it boiled out the vent.
also the shop that put the new front axels in were sent the wrong axel and it had too much of a shoulder to properly fit the t case..so they doubled up on the seals...it only cost me 927.56 to find all this out...T
