2000 gc 3.3 mpgs
#41
correct me if im wrong but to calculate fuel mpg is fill the tank, drive x miles, fill back the tank and divide number of miles driven by gallons used, right? that is what i did
as for the brakes, i jacked the van and hand turned the wheels, i didnt feel any resistance, the van is a fwd by the way. maximum weight 95% of the time is 3 people.
there is a check engine light on, but nothing to do with emissions, it says torque converter solenoid, however the van runs the same as the day we got it, no hard shifts what so ever
#43
#45
#46
#47
Another factor that contributes to gas mileage and is never mentioned is parasitic drag due to wheel alignment. I have been experimenting with different toe settings and have found that my 2003 GC reacts very positively to a bit of toe out. Just how much is a matter of trial and error with the sweet spot being somewhere around 1/8" toe out. My instantaneous mpg on the overhead console has been reading 30+ mpgs at 65mph on level freeway. On my last fillup I averaged about 24mpg and ran 475 miles until I literally ran out of gas and had to call AAA. ( I now carry a red plastic 2 gal gas can under the passenger seat)
Damn gas gauge said 1/4 tank but was really empty!
Hope this helps,
Joe
PS: Guys, don't ever run out of gas with your wife in the car, you'll never hear the end of it!
Hope this helps,
Joe
#48
Hey dodge, you still messing around with 4cylinders, I used to read alot of your post there, I can attest to the 4.7 dropping vlave seats. Watched a friend of mine work on 2 engines that did that... anyway. i have a post on #1 misfire,, Can you read it and give me some ideas. Man i's brain dead after everything i have checked, need some serious help thanks,
