1996 A604 Range/Neutral plugs to New A604
Old Mar 29, 2011 | 04:20 PM
kevgene's Avatar
kevgene
Default 1996 A604 Range/Neutral plugs to New A604
I'm reposting this with correct info. this time. If you can help I'd appreciate it.
I have a 1996 Caravan 3.3 with an A604 with the two seperate sender connections for the transmission range sensor & neutral position switch on SIDE of case. I need to be able to adapt the wiring to the one single transmission range sensor connection on the TOP section of the case by the module on the newer '98-up A604 transaxle. Thanks
Old Mar 29, 2011 | 10:20 PM
master tech's Avatar
master tech
Site Moderator & Tech
You have the 1996 1/2. That means you have the mid year when dodge change over to the TRS sensor. That means you can only replace the transmission with an early year. 1993 to 1996 1/2.
