05 Grand Caravan ABS and cruise control not working
Old Apr 17, 2011 | 04:58 PM
baller95's Avatar
baller95
Default 05 Grand Caravan ABS and cruise control not working
Hey guys my 05 Grand Caravan has some issues. The cruise control doesn't work and my ABS doesn't either. The ABS light is always on and I didn't find any blown fuses in the fuse box located in the engine bay.
Old Apr 18, 2011 | 11:12 PM
master tech's Avatar
master tech
Site Moderator & Tech
You'll need to scan the ABS and the speed control system for stored codes.
Old Apr 19, 2011 | 11:21 AM
Pecke's Avatar
Pecke
That happened to me too. I scaned and it told me there was a voltage issue with the ABS (I forget the exact code wording). I removed the battery and unclipped the fusebox. There was a corroded wire running to a blue plug. I fixed that and it cured the ABS problem. I erased the codes after, and it has been fine since, and the ABS is actually working again. one thing that tipped me off was corrosion on the fuse tabs. I work in electronics, and have good tools skills. I'm a novice with cars though. It was a good learning experience.
Old Apr 20, 2011 | 03:27 PM
baller95's Avatar
baller95
Thanks for the answer guys, I don't have a scanning tool though so I'll go to a repair shop nearby and ask for one.
