1999 dodge caravan: Dash lights out
Old May 1, 2011 | 01:10 AM
dodgecaravan99's Avatar
dodgecaravan99
Default 1999 dodge caravan: Dash lights out
odometer, tach, speedometer, temperature gauge etc. What would be the likely cause after fuses and battery have been ruled out?
Old May 1, 2011 | 03:07 AM
klock89's Avatar
klock89
I recent;y bought a 97 Dodge Grand Caravan for the Fiance, She had the same problem, it started out as an Intermittent problem, then became a permanent issue... I found I could get it to work by beating on the dash on both sides of the steering wheel as a temp fix... but would be off again next time I start the van. So I tore the dash apart to fine a lose connection on the instrument panel wiring harness connector to the board.
hope this helps.
