Oxygen Sensor 97' Dodge Grand Caravan
Old May 4, 2011 | 02:38 PM
cargod1's Avatar
cargod1
Default Oxygen Sensor 97' Dodge Grand Caravan
Well at it again with the sensor change, Can anyone tell me were Sensor 1 Bank 1 is ? Thanks-
Old May 4, 2011 | 05:54 PM
Cougar41's Avatar
Cougar41
You have two sensors. One is mounted in the top of the exhaust manifold just behind the engine. That's the one you're looking for. The other is in the exhaust pipe under the van just aft of the cat converter.
Old May 4, 2011 | 11:08 PM
cargod1's Avatar
cargod1
By any chance would the size of the sensors be different ? it looks a little tight behind the engine but it looks as it might be smaller than the one after the cat.
Old May 4, 2011 | 11:56 PM
master tech's Avatar
master tech
Site Moderator & Tech
They are both the same size, 7/8 or 22mm. You should use a o2 sensor wrench.
