Key cycle method
Old May 4, 2011 | 07:14 PM
scotter5's Avatar
scotter5
Default Key cycle method
Heard when engine light comes on go get it scanned or try key cycle
Please explain what key cycle means.
Old May 4, 2011 | 09:48 PM
JoshRamMiami's Avatar
JoshRamMiami
Im no expert but when you need to ' key cycle ' it usually means to turn the ignition off and on about 3 times.
Others will be by to explain better if im wrong.
Old May 4, 2011 | 11:59 PM
master tech's Avatar
master tech
Site Moderator & Tech
Thats correct, Some models not all will give you a stored PCM code. But if you get a P0700 code, that doesn't mean thats the only code for the transmission. You would need to pull the codes out of the TCM.
