Constant, suspension knocking. Loud under the dash
Old 07-06-2011 | 11:21 AM
211's Avatar
211
I don't feel the knocking in the steering or the way the van handles. It's just a horrible noise right now. If the rack & pinion were wearing I imagine I'd feel it through the steering wheel going over bumps and whatnot; at least when the r&p in my Subaru went out that's what I experienced.
Old 07-06-2011 | 08:05 PM
PWR's Avatar
PWR
It's likely not the strut bushings as they would make a noise when you turn the steering wheel, especially when you're parked. So, I have some questions;
1) Are you sure that the sway bar links are tightly bolted on to the strut and sway bar? Even though you've replaced the links they may not be tight enough and can move around when you're driving.
2) Have you checked the sway bar bushings? They're located on the bottom of the firewall and attach the sway bar to the body.
Cheers
Old 07-07-2011 | 11:13 AM
211's Avatar
211
Cheers
The end links are tight that's for sure.
While I had the end links off I had a look at the bushings. There didn't seem to be any physical play the sway bar at the bushing location.
Is there a way to check the strut bushings without taking the strut out?
Also If I were to tear into the strut how likely is it that I'll have to replace the upper and lower spring damper- the rubber pad the spring seats in?
Old 07-07-2011 | 07:58 PM
mfahey's Avatar
mfahey
I'm in largely the same place. I've replaced both the links and bushings with some improvement but there is still noise when going over bumps. It has been suggested that the lower control arm bushings might be the problem but I haven't had an opportunity to check them or have them checked.
I will say that the lower spring shackle bushings were worn almost all the way through so it wouldn't be out of the realm of possibility that the fronts are bad as well.
Old 07-08-2011 | 09:55 PM
scotter5's Avatar
scotter5
Hi 211. I had this same problem started yesterday. Drivers side, suspension area. Thought it was cv joint b/ it occured as the revolution of the tire tured, but sound was not there when i troubleshooted while driving in reverse.
Ok, here's the clincher. My front drivers side lugs were not tight. Wouldn't it be great if that was your situation. Maybe also something down in the brake area. Wish i was there for a second set of eyes. Many hands, make light work.
scott
Old 09-04-2011 | 10:35 PM
Hate em but keep buying em's Avatar
If its constant not just when hitting bumps etc. I would think about the cv joints.
Old 09-06-2011 | 11:10 AM
211's Avatar
211
Sorry I forgot to update this post...
Replaced both upper stut mounts. Noise is GONE! Totally silent.
While I was in there I did the front brakes and replaced the rotors. Total time to complete the job was less than 4 hrs; not including compressing the springs which I finally just took down to the local alignment shop.
Old 09-07-2011 | 12:23 AM
master tech's Avatar
master tech
Site Moderator & Tech
Nice job!
