Courtesy light, alarm, and power locks not working after radio installed
Old May 6, 2011 | 09:51 PM
MM546's Avatar
MM546
Unhappy Courtesy light, alarm, and power locks not working after radio installed
After I had a new radio installed, the following problems were created:
1. Courtesy light does not come on when I open the door
2. I can't arm the alarm with the remote control
3. After I turn off the engine, I no longer have accessory power where I can operate the power windows
4. When I unlock the van with my key, the power locks don't work to unlock other doors.
5. After locking the doors and closing them the alarm no longer arms itself
What can I do to fix this?
What should I check?
Does anyone have electrical schematics to help me fix this?
Any help would be appreciated.
Old May 6, 2011 | 10:40 PM
baller95's Avatar
baller95
What year is the van? Did you use a wiring harness or did you cut and connect the wires?
Old May 9, 2011 | 11:20 AM
MM546's Avatar
MM546
The van is the 2002 model, and I saw the installer connect the wiring to a harness.
Old May 9, 2011 | 12:07 PM
baller95's Avatar
baller95
Hmm it should be straight forward I just installed a new Sony deck and subs to my 05 Grand Caravan without a harness and everything works great! There harness could be faulty, you should bring it back and ask them to replace the harness.
Old May 9, 2011 | 07:35 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Were the lights working before you left the shop?
Old Jan 24, 2012 | 10:27 AM
Marklorenzo's Avatar
Marklorenzo
Bump. I am having the same problem with my ram. All lights and key fob/door locks worked until I installed an aftermarket radio. Did not use a harness. Ran a new Ground/power wire. Only wire I hooked to stock harness was the accessory remote wire.
